Unread 04-29-09, 06:20 PM
I start the rear first on the O-2 because my battery is just inside the baggage door, plus, you can clear the rear engine verbally without the front one running. Yell out "Clear Rear", verify no one present and crank. I can visually clear the front prop.
With the front engine running, you cannot verbally clear the rear over the noise.
