The field circuit breaker would be a good place to start as it does supply both alternator as your 337 has one voltage regulator to supply both alternators, using the run/stby switch overrides the voltage regulator and is used for alt restart in the stby selection.
If the field circuit breaker does not cure the problem let me know. Pete |
