Old 08-14-08, 02:01 PM
Jakes
Why don't you go the hole hog and fit an external antenna, as this the only way you are going to pick up a proper signal and fitting the antenna is easy on the 337 as the the roof is to get at, route the cable down the center pillar or down the windshield side pillars, and you will find that it will work, same with your Wx antenna
Pete
