Old 07-13-07, 01:27 AM
Fuel Valve Leaking
I have a fuel selector valve leaking...more like sweating...from inbetween where the top half mates the bottom half. I looked in the parts manual but it shows "NP" for the gasket that is supposed to seal it up. NP means not procurable, and of course no part number associated with it.
Has anyone ever worked this problem before? Do you make your own gasket? RTV?
Old 07-24-07, 01:46 AM
Still have a sweating valve. Although, selecting the "OFF" position seems to stop it while on the ground. Any suggestions on what to use for a gasket?
Old 08-12-07, 09:45 PM
Any one? Doesn't anyone know what is a good replacement part for the wing tank selector valve gasket?
Old 08-12-07, 11:24 PM
Have you tried tightening the screws? I did that to one on our E model about 3 yrs. ago. Hasn't leaked since Knock on wood!!!
Kim
Old 08-14-07, 10:11 PM
Yes, I tightened the screws as much as possible with a small thumb screw. But it is so tight in that area. Did you have to remove the valve to tighten it more?
