Unread 08-11-20, 08:33 PM
Rear engine cylinder head temp
Yes, the rear engine does run warmer. Sometimes I'd crack open the rear cowl flaps just a bit, which would help.
I'm having two EI MVP50P's installed now so I should have some more accurate info in a couple more months.
Wow! The courtesy light is bright! Thanks in advance for the wiring picture.
Rick
N337K-FT337GP
KLOU
