Old 11-15-08, 03:49 AM
gkey's Avatar
gkey gkey is offline
This is what the panel is going to look like so far. Again, the ADF and attitude instruments should be reversed.
To the Blue Room!!
Jakes Dekker
Old 11-15-08, 09:52 AM
I know that the Aspen is the latest, coolest thing out there, but in your considerations, did you consider the Bendix King PFD??
I like that it is larger, and very cool looking
https://www.bendixking.com/apexedgeseries/index.html
Old 11-15-08, 10:55 AM
gkey's Avatar
Very valid question. Short answer: no. I did not even occur to me. I guess this one went past me because I do not regard myself as a B/K fan.
But at quick glance the B/K MFD looks very cool, I agree. I'll have to read up about it first though. For starters, if I have to give advice so far to others planning a similar venture with their panel, I would caution on available estate on the panel. These panels are a lot smaller than we think. The B/K is 8.5" wide x 7" tall. It actually works out better (read:smaller) than the 3-piece Aspen glass, which is (per unit) 3.5" wide x 7" tall. Something to consider indeed. With my setup I do not have enough panel space to install all three 2" mini instrumetns in a cluster together, hence the mini-ASI and mini ALT on the left side and the normal attitude indicator on the right side (it would just look funny if it was a mini too).
Another winning ingredient is the cheaper price for the B/K vs. the full set of 3 Aspens.
OTOH, the Aspen can direct the MFD to take over PFD duties in case of failure, which the B/K can't do. It is very unlikely that all three or even two Aspen screens will die simultaneously.
Make no mistake, I am still very smitten with the Aspen setup. But I do know of at least 2 problems it has (defaulting to HDG mode during landing and attitude problems in certain conditions), but Aspen is working on a software solution to be released (hopefully) soon. I would like to study the B/K unit as well and see if it has similar quirks.
To the Blue Room!!
Jakes Dekker
