Unread 09-03-17, 06:24 PM
JimC's Avatar
JimC JimC is offline
Horton/Robertson differences
Are there any differences between these two that can be indentified from photos or an exterior inspection without dropping the flaps?
Unread 09-04-17, 10:44 AM
Maybe if they were side by side. Not sure????
Unread 09-06-17, 11:09 PM
general's Avatar
general general is offline
I've had both my Robertson had a fence on top of the wing going from the front to the back just outside the flaps. My Horton did not have the fence on top of the wing, but the Hortons also have Vortec generators that fit on rear engine cowling just below the engine. The Horton has other differences on the Leading Edge of the vertical tail Boom
General Sky
Unread 09-07-17, 07:19 AM
JimC's Avatar
I've seen Horton with stall fences, and I've seen Robertsons with aft cowling VGs.
Unread 09-10-17, 05:59 PM
rrolland rrolland is offline
The Horton has the drooped leading edge extension as well as the fences just outboard of the flaps.
Some aircraft -such as mine- also have the Robertson VG's under the rear engine cowling.
Hope this helps.
Unread 09-10-17, 07:53 PM
JimC's Avatar
I think the problem in finding differences is that Horton basically copied Robertson. Both have a leading edge cuff, stall fences outboard of the flaps and large rear cowling VGs.
Unread 09-14-17, 09:16 PM
AP AVM AP AVM is offline
Here is a picture of a 77 337G Skymaster II with complete Horton kit installed on it. Wing tips droop plus have formed winglets on them.
Unread 09-16-17, 09:43 PM
JimC's Avatar
The winglets are not part of the Horton STOL STC.
Unread 09-17-17, 03:48 PM
JimC's Avatar
I think I found a partial difference:
All Robertson kits came with tail boom fairings. Some Horton kits had tailboom fairings, and you can purchase tailboom fairings without either STOL kit.
So from logic 101:
If it doesn't have tailboom fairings; it doesn't have a Robertson kit.
Can anyone find an example where this is false?
Unread 09-17-17, 08:37 PM
If it has a Robertson the seller would be smart enough to brag about that system as it is worth much more money. If it just says STOL kit it's probably a Horton. I have never seen a STOL kit without the boom fairings. Not saying they aren't out there I just think that's a poor identifying component. Why would you rely on the ad without calling and talking to someone that represents the plane? Anyone that knows anything should be able to verify the system by extending the flaps and see if the ailerons are inter-connected.
Unread 09-18-17, 07:54 AM
JimC's Avatar
Well, one I was looking at was being sold by "a friend" - that's not too uncommon. They didn't know which STOL it had. I know of at least one plane currently listed online by an aircraft dealer that says "STOL kit installed" - and I'm sure it's a Robertson.
I did find one more way to check: Robertson has a remarked ASI with a slower white arc; Horton does not.
Unread 09-20-17, 04:46 PM
MelsML55 MelsML55 is offline
MelsML55 is on a distinguished road
Mine has the cuff on the leading edge and a small spoiler(air gate) at each end of the wing.
Name:	Screen shot 2017-09-20 at 3.37.26 PM.png
Unread 09-20-17, 09:22 PM
You also have FENCES on the top of the wing (one on each wing) and VORTEX GENERATORS on the rear fuselage and BOOM FAIRINGS on the connection of the boom and the vertical stab
The spoilers you refer to on the end of the wing are droop wing tips. Which yours are pretty much Cessna Stock tips not the radical droop that Horton offers as an option
Unread 09-25-17, 08:00 PM
kilr4d's Avatar
kilr4d kilr4d is offline
Nice paint Mel.
Start a thread, tell us about your bird.
_________
John K
1977 337G
CNC3
Unread 09-25-17, 08:58 PM
JimC's Avatar
Is yours a Horton?
