Originally Posted by hayesjaj
The senders for yours are essentially wired in parallel (via the conditioner box) because the tanks are plumbed together. The multiple sensors are used to determine fuel level when the wing isn’t level and the fuel moves toward one side or the other. You shouldn’t need the capacity of the aux at all. Give EI a call and they will walk you through it but only specify two tanks total for your order.
Thanks, that makes a lot more sense to me, but I am not mechanical at all. I'll just specify the 2 tanks and I assume the wiring will tap into the conditioner box for the value. Appreciate the help
