Unread 07-28-15, 07:39 AM
chrisktx chrisktx is offline
I can confirm that three years is a long run for an aircraft battery.
Unread 08-01-15, 08:27 AM
bking bking is offline
bking is on a distinguished road
Will a Concorde replacement fit the original 337G battery box with any modifications?
Unread 08-02-15, 01:57 PM
Without any modifications? Yes, check the Concorde site for applicability. No modifications required to the original box
Unread 09-04-20, 12:18 AM
Gill vs Concorde
Today, my 2 year old G242 battery died. Showed 24.3v unloaded, but volts dropped to 9.8v upon cranking—obviously no start. Worked great two weeks ago. Use a Schauer 24v ground power unit and battery charger routinely. Thought it would be a good battery minder...but maybe the charger/maintainer hastened it’s demise? According to logs, prior to 2018, the bird got a new battery in 1988, 1999, and 2009. So, old Gill batteries were apparently pretty good. Thinking of swapping to Concorde. A&P votes for Concorde also. Concorde site calls for the RG 24-12 as the appropriate battery for my ‘77 NA G model. Anyone using this battery? Where do you like to shop for one?
Unread 09-04-20, 08:57 AM
Are there any Lithium Ion batteries PMA'd for the 337? They are taking over in the Bonanza world. Half the size and weight, far more CCA. Would love to have a LI option for our planes! Comes in its own box too, so get rid of that ridiculously expensive battery box, especially the $1000+ plastic battery box in late model 337s.
https://www.truebluepowerusa.com/pro...nanza-a36-stc/
I may install one via 337 if no PMA solution is available. (I guess 337's for 337's is a tired joke by now on this site )
Unread 09-04-20, 10:25 AM
Welp, I followed your link which re-directed me to mcico.com for purchase info. It appears the STC for the Bonanza is $8035.00
Maybe I'll just stick with a Concorde RG 24-16.
Unread 09-04-20, 10:29 AM
My choice has been Concorde for the last 20 years. I have paid the extra for the platinum series and haven't been disappointed.
I change my battery every 3 years no questions asked. A lot of guys say if it starts it's good but that is not true. I am a serious flyer and routinely fly IFR, over lakes (big ones) and night so I have no problem with buying new and staying fresh. It's the one time you loose charging that will make a believer out of you.
I also use a Battery Minder made specifically for the Concorde battery. It stays on my plane whenever it's in the hangar
Unread 09-04-20, 10:39 AM
That can't be right. I must have linked to the wrong product. I'll check in the Bonanza forum I belong to and get the right info. The cheap Bonanza owners I know that have LI batteries would never spend that kind of money on a battery!
