Unread 08-09-10, 04:37 PM
Remember, the small drain tube that Ernie is referring to passes through the fuel tank before exiting below the wing. This has seen corrosion issues in some cases causing the moisture to accumulate in the fuel tank. Check these drain tubes regularly for blockage and for potential seepage into the fuel tank.
