Unread 05-10-04, 04:05 AM
Damon Banks Damon Banks is offline
Member
Damon Banks is an unknown quantity at this point
Kevin,
Not sure that the access panel will be much use to you to replace a rear vac pump - it's located fairly high on the engine and the access panel is right in front of the rear alternator, and the mags are above that!
You (or your mechanic) might gain better access by removing the top of the rear cowl instead!
Cheers,
Damon
