Unread 04-12-24, 09:52 AM
Ryann
Wow you ingested something bad that destroyed the impeller of the turbo. you have to take that nut off the through stud. You can use an extremely long extension and the 9/16inch socket on the left side of the engine to hold the nut on that side as you remove the nut on the RH side, then remove the bolt that goes into the RR engine mount. Your through stud is significantly longer than mine, i do not have a spacer on mine. When i had mine off last fall the ear was broken for the through stud, added a reinforcement then put back together.
Bracket 4 has to also come loose from the rear accessory housing i use snap on swivel socket for that, 1/2 inch if i remember correctly. my aircraft is a 74 so both side panels are able to be removed, those early aircraft that do not have removable sides what a PITA that would be.
Dan
N67S
