Unread 09-28-22, 10:23 AM
Frank Benvin's Avatar
[QUOTE=mshac;2858
My suggestion would be to check the fluid level in the power pack before doing your bounces. This will help with confidence, and its something we should be doing anyway. Takes all of 60 seconds.
If you don't how, no shame. The center pedestal has a cover at the bottom attached with velcro. Remove it, and the dipstick should be apparent. Remove that and verify fluid level. If low, add your choice of hydraulic fluid. I use automatic transmission fluid, but you can purchase dedicated "hydraulic fluid" at the Tractor supply. Forklifts and tractors use it. The auto supply will also have "jack fluid". IMHO its all the same.
Don't you have to use the correct fluid that is compatible with your system If you use the wrong fluid, it can wreck you seals and cause failure
I only use MIL-PRF-5606H - ROYCO 756 in my 1967 337b which is specified for it
Frank
1967 337B
