Unread 09-18-02, 07:26 PM
SkyKing SkyKing is offline
Sten,
There's an even easier method of determining 'which' box you should have installed, as well as other installed equipment, and that is to contact either Reims/Cessna or Cessna in Wichita and secure a copy of the Original "Weight & Balance and Installed Equipment Data" list for your specific tail number (as it came from the factory). This data will list a "Control Number" that specifies every component installed.
If unable to contact Reims/Cessna, I would try the Cessna Technical Support Department in Wichita, Kansas at (316) 517-5800.
BTW, you'll find a whole slew of 400 avionics items in Trade-A-Plane. E-Bay is another source under "Avionics".
Good luck on your project!
SkyKing
