Unread 06-02-05, 10:15 PM
You might want to check the P leads real well. Look carefully where the shielding ends and make sure its not able to touch the center conductor. make sure its not cut through anywhere, like where they go through the firewall. You might want to try running it with the P leads disconnected. If you do be careful for the mags will be hot.
Kim
