Unread 10-13-03, 02:47 AM
Danger,
I see the NTSB has an accident report dated 02/02/85, in which a person was injured by the front prop. It contains minimum details.
Click here for the NTSB report
Do you know the serial number? I'm guessing it was 337-0621. I came to this conclusion from the serial numbers of aircraft with similar N numbers:
N2313S -> 337-0613
N2315S -> 337-0615
N2322S -> 337-0622
N2324S -> 337-0624
N2325S -> 337-0625
Based on that, an SN search shows the aircraft is now registered as N769DC, in Monroe, NC:
Click here for the Landings Serial Number Lookup Form and then enter 337-0621 in the "Serial Number" Field.
