Unread 01-21-03, 09:21 AM
N69S
re additives
Franciso
AVBlend (lenkite) is probably harmless based on my knowlege of the product. Think the analysis shows it is a fine grade mineral oil. It definately does "chew up" carbon. I have used it in the past and never had a problem with fouled anything, however, I do run around lean as possible on the ground.
I do not believe it will harm the engine but if you do not have a carbon problem with turbos etc. then I rather doubt it is worth the money. All the other claims are rather rediculous!
Lenkite has been around since the mid 30's
your choice. Cuban cigars or lenkite ? or.... 41 dollar hamburgs. Lots of ways of blowing $$ Hair transplants?
Oil changes every 25-30 hrs makes more sense.
... MHO.
