Unread 09-03-23, 02:16 PM
bigcheese
99.275% its the throttle switch
T
On top of the throttle for each engine is a little microswitch.
As I recall, the gear horn goes off if either throttle goes back near idle and ger NOT down.
I believe they both have to be closed.
Annoying little buggers.
Easy to check w cover off and a meter.
They are a common microswitch.
Aka 'digikey' common.
Any shop on any field should be easy to fix / adjust or replace
