Unread 09-28-22, 11:20 PM
Frank Benvin's Avatar
Cessnadriver - I only use MIL-PRF-5606H - ROYCO 756 in my 1967 337b which is specified for it
I was quoting mshac he said to use jack fluid or transmission fluid. I was stating that it might not be compatible and hurt the seals and o-rings causing a gear failure or also a brake failure. Brakes and gear use the same oil
1967 337B
