engine shock mount SDR
SteveG-
Hello, I replaced the rear mounts. But I used the Barry mounts, at $75 per set, bought them from a Global salvage. It was the correct mount listed on the Barry Mount website. I did have a problem with them, I had to remove one of the washer under the nut but it was fine since the mount has a very thick material on the mount halves. My biggest problem was to get the damn bolts to line-up. I had to use all sorts of pry bars and adjust the hoist to get them in line.
Good luck, BILLS
