Unread 07-12-22, 05:10 PM
I suppose that is a good sign that uAvionix is not aware of any issue. I do however understand your logic and the reason for the concern. I feel like I have seen other C337's on this forum with the same install you have with the TailBeacon. Hopefully you will receive some feedback from someone. In the mean time, you will certainly be able to figure out quickly once you're back in the air if the issue actually exists. Good Luck....
Ed
