Unread 04-23-22, 04:04 PM
kbecker kbecker is offline
I just watched a youtube video of the accident aircraft, may have been taken on the day of the accident. It was some ground ops at Whiteman. There is one view of the aft of the aircraft as it is taxiing away. The back and undercarriage of the plane look pretty dirty---may be oil, hydraulic fluid, dirt, etc. I can't tell.
Perhaps there were issues with the hydraulic system that could have been noticed earlier if the plane had been cleaned. I always try to do a post-flight inspection including getting under the plane to look for oil, hydraulic fluid, etc.
I had my gear doors fail to close one time--It turned out that I tried to retract the flaps and retract the gear at the same time. It tripped the hydraulic gear motor breaker and left the rear doors open. After resetting the breaker I was able to cycle the gear and the rear doors closed.
