Unread 07-10-21, 10:34 AM
Originally Posted by Skymasterdriver View Post
Can we buy you wire diagram and 337 paper work and us zeftronics regulators or is the Cessna ones all we can use ?
This upgrade only covers factory Cessna voltage regulators. Its possible that a system could be designed using the Zeftronics VRs, but it may well be "a bridge too far" for an easy field 337 approval because it strays too far from the original design.
This modification takes an existing, approved system from 400 series aircraft and applies it to the Skymaster, with no changes to the POH or placards. The FAA seems to view this approach favorably.
