Thread: Gear issue
Unread 06-14-21, 08:27 PM
Originally Posted by cjordan View Post
Anyone had their gear horn go off when retracting the gear and the gear not move at all? Cycled gear handle 3 times and same result.. as soon as up, pump ran, horn and no movement. waited a few minutes then tried it again.. retracted normal. When I came into land I was ready to have to pump, etc… Non event, totally operated as normal.
Ideas?? G model
It sounds like the landing gear safety switch on the nose gear is out of adjustment, or is broken, because the horn sounds when the gear switch is placed in the retract position. The switch must be thinking the airplane is still on the ground.
Rick
N337K-FT337GP
KLOU
