Thread: Accumulator
Unread 12-07-20, 09:37 PM
Ace of the Atmosphere
Look in the type certificate data sheet, if its required it will be listed here. If its not listed, you may remove them. Look for the weight and arm in your T.O. 1L-2A-5 Technical Manual. Item number D-1 for the rear accumulator, 5 lbs at station 207, and 5 lbs at sta 35 for the front accumulator, item A-1.
Removing the accumulators is no different from removing the ARN-83 Receiver or the APX 64 receiver transmitter.
