Unread 05-14-20, 12:52 PM
it sounds like the gear warning horn switch on the throttle bodies got moisture in them
I had it happen on several of our 337's. you can put RTV on the connections where the wires solder to the switch or buy cessnas upgraded switch witch has a bolb of epoxy over the connections. check out cessna service letter ME77-24
Kim
