Unread 05-13-19, 03:54 PM
Tie Bar
Dave,
The tie bar is good for 428 Amps...ha ha. Yes, I used a wide piece, however that does not add anymore height than a skinny one - but you are right, that is what makes it tight. I would love to see your pictures of it mounted - had considered some spacers or improvement of mounting it rather than just using the side panel as a "gasket".
Planning on a thin Lexan lining for it - installed on aircraft side of the panel. Especially for skin side and top (prevent FOD from dropping down into back of panel is paramount for me).
Thanks for the help!
