Unread 11-12-17, 05:17 PM
Bill
Is the gear working correctly or are you trying to toubleshoot something? The operation you describe above should work unless there is a switch somewhere not closing that allows the valve to shift. Leave the doors open and when you fire up the engine just cycle the gear handle down and the doors should close. Not sure why they wouldn't with the hand pump
