Unread 08-12-16, 03:55 PM
Red Air Rambo's Avatar
Ok, if we are talking about the cable on the valve off the Janitrol Heat Exchanger, it runs down 1st attaching to an arm off the exchanger, then back to the battery, then up to a point on the firewall midway between the vacuum pump and inner (lower) starter contactor (should look like a quarter with a hole in the middle). Then thru the bottom of the avionics bay and into cabin behind the center console then parallels the defrost cable to the lever. FYI, mine is a 73.
--Brent
