Unread 06-19-11, 12:53 AM
atsiii atsiii is offline
atsiii is an unknown quantity at this point
Yes, it's up on my jacks right now, and it's the same with the mule or hand pump. I think it's the same in the air, too, which would explain some abnormal wear on the struts where the struts are contacting the downlocks and pushing them back out of the way.
It seems like they should remain retracted. If we stop mid-cycle and physically push the downlocks into a retracted position, they remain there out of the way until they are popped out to lock the gear once it is in place. When you raise the gear, they pop back to fully retracted to unlock the gear, and remain there while the gear goes up and locks. But when you put the handle in the gear down position, they float out a few inches instead of staying retracted.
