Thread: Cessna C337 SID
Unread 01-29-10, 06:41 PM
Regarding the last two messages:
1. Cessna, not the FAA, is writing the SIDs, but under a mandate from the FAA, who in turn is responding to Congress after the 1988 in-flight failure of a high-time Aloha Airlines Boeing 737, where a section of the upper fuselage ripped away because of fatigue. Initially only transport aircraft were considered but that was later expanded to cover smaller aircraft.
2. But, yes, even though it's being done under FAA auspices, the FAA has made it clear that it doesn't apply to Part 91 -- in fact, it doesn't apply to some Part 135 operations, either (see the FAA’s Final Rule on the matter at http://edocket.access.gpo.gov/2002/pdf/02-30111.pdf). Also, although the referenced letter may apply to large and turbine powered aircraft, the rationale and underpinning for the opinion make it crystal clear that the policy applies to all Part 91 operators. One other point that has not been mentioned: on the Cessna 400-series SIDs, which have been implemented now for several years, Part 91 operators do not have to comply and few do(except for the single SID that became an AD).
In a 1/27/2010 Message in the thread entitled "How are you going to handle the SID?", Herb's point 5 is short and to the point: "Unless these inspections become AD's we will NOT have to comply". Based on all we know -- principally the FAA’s Final Rule and Notices -- he's right.
