Unread 01-26-09, 08:24 AM
As quoted on AvWeb today:
"As for Canada and Mexico: Canada has not yet required that aircraft flying in its airspace be equipped with 406 MHz ELTs. The country is planning a two-year conversion period and has yet to set rules for the transition, according to AOPA. Flying to the Bahamas will not require 406 MHz equipment, but that may change after January of 2011. Mexico will allow U.S. aircraft using 121.5 MHz ELTs to fly within the country until the end of June 2009, unless they reach a mandatory ELT battery replacement date first. The Cospas-Sarsat System has been and will continue monitoring signals transmitted on 406 MHz."
