Unread 01-15-09, 08:54 PM
If the other blade is good, there is of course a significant price advantage if you can find a replacement blade. If the aircraft still has the original model (and the log books should tell you that), then the type certificate (easily found in the FAA's website) will tell you what to look for. Don is probably the best person to guide you.
