Unread 02-07-08, 10:31 PM
No nicks on the rear prop. Good suggestion by Kim to replace with screws and nuts. If Kim is right and the fiberglass inlet causes the rivets to pull through, then a recurring inspection every time you add oil to the rear engine may be prudent.
