Unread 10-01-18, 06:50 PM
kilr4d's Avatar
kilr4d kilr4d is offline
Couple of notes from my annual
In for annual right now...snag list isn't too bad. Couple of things I didn't expect though:
  1. Front exhaust pipes badly corroded and simply wore out. Replacing both.
  2. Both gascolators have very brittle plunger tips and corrosion on the standpipes. The brittle is age, but the corrosion means that the fuel has had water in it at some point. Scary.
So far the rest has been standard "old airplane" stuff.
_________
John K
1977 337G
CNC3
Unread 10-02-18, 12:39 PM
kilr4d's Avatar
Update...brake discs are below minimum measurements. That's fair I guess, our birds are pretty heavy.
FYI, Cleveland discs are almost 50% more money than the Rapco discs. I'm purchasing Rapcos.
_________
John K
1977 337G
CNC3
Unread 10-03-18, 09:50 AM
Brakes
John
Check with APS, highly recommend
http://www.apsbrakes.com/
Unread 10-03-18, 09:59 AM
kilr4d's Avatar
John
I checked and there's no stock in Canada, I had to go ahead with the Rapco's.
_________
John K
1977 337G
CNC3
