Unread 10-08-17, 10:30 AM
tomcomet's Avatar
tomcomet tomcomet is offline
tomcomet is on a distinguished road
Pitot Port
My new 1977 Reims built 337G has a pitot port on the leading edge of the left strut and no pitot tube. Are they all like this or is mine unique? Is there any differnece in operations with this system? It seems to work great so far...
Unread 10-08-17, 09:40 PM
1973 and on had that pitot. Heated and all, not sure why they went with it but there you go
Unread 10-09-17, 12:32 AM
LostKiwi's Avatar
LostKiwi LostKiwi is offline
It messes with the avionics shops when it comes time for the alti-calibration, purely because they're not used to seeing it.
There is a T fitting just above it in the wing that you can tie into.
Its also worth noting that the usual "tape over top, connect the unit as required" doesn't work worth a damn. There is always an air gap between the probe itself and the strut fairing, so it'll register as a leak in the Pitot system.
Undo the two screws on the leading edge, and lift the thing out. Much better results!
Static ports on either side of the front, as per a "normal" Cessna.
Leighton.
Unread 10-09-17, 11:07 AM
kilr4d's Avatar
kilr4d kilr4d is offline
Originally Posted by LostKiwi View Post
...Undo the two screws on the leading edge, and lift the thing out...
Spend many hours cursing at screws that haven't been touched in 40 years....
_________
John K
1977 337G
CNC3
Unread 10-09-17, 10:48 PM
LostKiwi's Avatar
The pain is real.
