Unread 11-16-20, 05:02 PM
Exclamation $14k 336 in FL - IN ANNUAL!
1695 TT airframe and engines. May be the original motors from 1963!!! Rear engine not running, he thinks its the mags: https://www.trade-a-plane.com/search...type=aircraft#
Unread 11-16-20, 06:54 PM
JimC's Avatar
JimC JimC is offline
That's a good candidate for an "Bush 336." Put some fat tires on it with a field approval, slap a Horton STOL kit on the leading edge, and go have fun.
1969 T337E
Unread 11-16-20, 08:09 PM
Its a good candidate for a multiengine time builder too. Once you get your ME rating, Skymaster time goes into the "multi" column just like all the other ME airplanes!
What would the fuel burn be with both motors pulled back to 2200 rpm? Maybe 16 GPH?
Unread 11-17-20, 09:46 AM
JimC's Avatar
Depends on the MP. The 337 POHs have an entry for 2200/18" @ 12gph. I don't see why you can't do that with the 336.
1969 T337E
Unread 11-17-20, 11:48 AM
Cool
100ll is $2.99/gal near me, so you could build multi time for $36/hr, plus oil and airframe. Pretty inexpensive, especially when you got the airframe for $14k!
Oh my - But the engines are old and scary! "That's why you have two, mam".
Unread 11-17-20, 12:02 PM
JimC's Avatar
Both engines were overhauled before the VAR crank AD. I'm guessing that the way to have this plane make sense is to buy it, fly it until you HAVE to open a case, and then part it out. You'd probably manage under $100/flight hour all-in if you can assist with annuals.
1969 T337E
Unread 11-18-20, 09:58 AM
1695 TT Airframe and engines - what makes you think they've ever been overhauled? Those cases haven't been open since the Kennedy administration!
Unread 11-18-20, 10:03 AM
JimC's Avatar
They're time capsules!
1969 T337E
Unread 11-18-20, 10:22 PM
GoByJet GoByJet is offline
GoByJet is on a distinguished road
This link is not working....do you have details or a revised link? Please and Thanks
Unread 11-19-20, 09:20 AM
JimC's Avatar
Post is gone; looks like it sold (quickly.)
1969 T337E
Unread 11-19-20, 01:29 PM
SOLD SOLD SOLD!!!
I'm surprised it lasted as long as it did. I'd have given $14k for it if I had it laying around, I knew someone else would too!
