Thread Tools | Rating: | Display Modes |
Riley Skyrocket for Sale
1976 Riley Sky Rocket N419
$170,000 or Best Offer Here is your chance to own a 1976 Riley Rocket P337! Cruise at 260 Mph at Fl 20 in pressurized aircondiontioned comfort. This is a very desirable year model because of the large fuel tanks and the sliding rear seats. Plane is rigged for ice boots. It has a hot pilot winshield and a hot prop on the front. Basic Stats: 3500 Total Time Since New 1100 SFREM Both Engines 1100 Since Complete Riley Conversion 1100 Front Prop 750 Rear Prop Avionics: KX155 Nav/Com (1) KY196 Com (1) KNS80 RNAV/DME KT79 Transponder/Encoder KR 87 ADF KMA24 Audio Panel WX1000 Stormscope King HSI KLN-90B GPS (IFR Cert.) Dual Glide Slopes Marker Beacons S-TEC 65A Autopilot/Flight Director with Altitude Pre-Select Equipment: Long Range Fuel (148 gallons) Riley Air Conditioning Horton STOL Hot Prop Hot Windshield Pressurized Mags Super Soundproofing Inflatable Door Seal Digital Fuel Flow Digital EGT and CHT Radar Fresh Annual Complete Logs Exterior: 8 White Base with Metallic Blue and Silver Trim (New Paint) Interior: 7.5 Gray Leather Perfomance Specs: Maximum Speed 260 mph Normal Cruise Speed 236 mph Maximum Cruise Range 1590 miles Rate of Climb Twin Engine max at Sea Level 1,250 fpm Single engine max at Sea Level 375 fpm Certified Ceiling 20,000 ft Takeoff Distance ( At gross weight) 945 ft. Takeoff Distance over 50 ft obstacle 1,500 ft. Landing Distance (At gross weight) 707 ft Landing Distance over 50 ft obstacle 1,489 ft. Gross Weight 4,700 lbs Useful Load (standard airplane) 1,595 lbs Fuel Capacity (usable) 123/148 gal Baggage Capacity 365 lbs Passenger Capacity 5 Engines (2) Teledyne Continental TSIO-360-CB Propeller 2-Bladed McCauley Wingspan 38.2 ft Stall Speed 55 mph Centerline Thrust No Critical V MC Call if interested 310-717-6865 Ask for Michael Scott Last edited by mikecfc : 12-09-04 at 07:41 PM. |
Photos of Riley Sky Rocket N419
Photos of the above plane.
Michael Scott |
More information requested
Could you send more information on your P337?
Additional photos, condition of engines, compressions etc. Thanks, Randy |
Skymaster
Please snd me pics of your Skymaster.... Thank you!!
Jim Burkhalter 704-904-0781 semitrailersrus@ctc.net |
Skymaster
Mike, you have a beautiful airplane.... Would you consider financing the aircraft with $30,000 down? If you would like to call and discuss the matter please feel free....
Thank you for yur consideration.... Jim Burkhalter 704-904-0781 semitrailersrus@ctc.net |
