Unread 04-06-17, 07:49 AM
kragby kragby is offline
kragby is on a distinguished road
rubber trim on 337p door needed
It's not the actual door seal, its the trim that goes between the interior plastic around the door and the metal door frame. I replaced the plastics but the foam trim molding is history and needs replacing.
Unread 04-06-17, 08:40 AM
Part number ?
Unread 04-06-17, 10:00 PM
rubber trim -
I have searched my parts manual and have not found the part. I don't know if it is original or added along the way. It dense foam, triangular in shape about 1/2 inch each side. I've searched a number of manufacturers for something similar without much luck. It was glued to the metal door frame and spanned the gap to the plastic trim. Any help appreciated.
Unread 05-02-17, 09:36 AM
kilr4d's Avatar
kilr4d kilr4d is offline
Can you post up a couple of pictures?
_________
John K
1977 337G
CNC3
Unread 05-02-17, 05:50 PM
https://www.aircraftdoorseals.com/
Unread 05-03-17, 07:21 AM
door trim
Appreciate the feedback but I'm assuming what was in there was some sort of nonstandard retrofit and have not located anything that would work. I found a satisfactory substitute however and may work well for someone else. The foam insulation for hot water pipes - carefully cutting a strip on the adhesive side around 1/2 inch wide worked quite well. The angle and slight curve of the adhesive side fit well and solved the problem.
