Unread 07-17-21, 09:44 PM
MD83driver's Avatar
Air Vents above radio stack
I am going to do upgrade on the radios in my P337H. The radios that are going in will require a height of 14.3", and with the air vents on top of the stack, there is only 13.5" available. If I relocate the vents I will have 15.25" available and this will get me my glove box back. Has anyone run out of vertical space and relocated these vents? If so where to and do you have any pictures. My interest here is only in getting info on the relocation of the vents, Thank you ahead of time.
They can't stop the signal.
Unread 07-18-21, 12:31 AM
If you want to sell that air vent assembly from the stack le me know, I need one
Dan Schultz
937-603-2459
Unread 07-18-21, 02:12 AM
My vents were relocated to the bottom of the stack. If you need pics, let me know.
Unread 07-18-21, 10:48 PM
My vents were removed from the center stack and the tube that supplied air to the vents is now located under the cabin altitude control knob in front of the pilot's seat.
N337K-FT337GP
KLOU
Unread 07-19-21, 05:00 AM
MD83driver's Avatar
Thanks, did you use any eyelets or reuse the outlet from the stack?
Unread 07-19-21, 05:39 PM
When I bought the plane, the vents had already been removed from the plane. The open scat tube is secured just under the altitude control knob.
I have a friend with a maker who I think can make a more aesthetically pleasing delivery method than an open scat tube. I have contemplated asking him to take a look at it.
I'll try to attach a picture.
https://linksharing.samsungcloud.com/ql0Xti7VPKx2
Rick
N337K-FT337GP
KLOU
