  #31
Unread 04-07-05, 12:47 PM
Can I get Allie Cat to fix my transmission?
Unread 04-07-05, 01:17 PM
Keven
Hey, Hey, Hey there!!!
Kevin:
Is that a euphemism for what I think it is? You dirty, middle-aged man! I'll see to it that she has no part of your "transmission" in the Keys, thank you very much!
Keven
CUMSHOT MOUTH
Unread 04-07-05, 01:31 PM
Darn.
Unread 05-03-05, 08:57 AM
Dale Campbell's Avatar
Electrical Power Failure on Take- off
I just got my 337H back from annual. The failure was the high-low
sensor that is mounted in the center console below the throttle quadrant. Thats why the DIS light would not go out. Dale Campbell
Unread 05-03-05, 10:10 AM
Thanks for the update Dale.
Unread 05-03-05, 10:42 AM
Thumbs up
There you go Dale,
Saw this problem on a 337G a while ago and the alternators going off line was more that likely caused by FOD going thru the rear alternator, caused a short inside the alternator for a second but enough time to cause a Hi volts which took out both alternators.
The rear 35A circuit breaker had popped and the HI/LO sensor had been damaged.
The circuit breaker was restored and the alternators ran fine, but the DIS light was on all the time. The HI/LO sensor was replaced and the system check out ok.
BTW a search of the rear engine bay was done nothing found, a look at the alternator turned up the same.
Glad to hear everything ok
Pete Somers
Unread 06-16-21, 11:44 AM
bking bking is offline
Can anyone please tell me where is the Hi/Low sensor located?
Unread 06-16-21, 01:53 PM
On a T337H they are located under the pedestal cover on the right side
Unread 06-16-21, 06:25 PM
JimC's Avatar
JimC JimC is offline
Item 32 (upper left, Detail F) in this drawing of 1970-73 planes.
What make & model do you have?
1969 T337E
Unread 06-16-21, 06:29 PM
My Skymaster is a 1974 model, s/n 1563.
Unread 06-18-21, 06:53 PM
JimC's Avatar
Item 30 in detail C for s/n 1563.
1969 T337E
Unread 06-19-21, 08:29 AM
Jim and Kim thank you for the help.
