Old 12-08-04, 09:45 PM
One VERY good reason for owning a 337!
Imagine yourself flying along in CAVU skies at FL190 above IMC conditions below you at 10,000' when all of a sudden one of your 337's engines develops a problem necessitating shutting it down, feathering and securing it. Not too much of a problem. You'd inform ATC of the 'problem' and seek the nearest airport, hopefully in VFR conditions and land. Now imagine yourself in a single-engine P210 at the same altitude and your engine has a catastrophic failure. This happened in November, and it's a chilling accident report to read, seeing that the pilot did everything pretty much right... up to the end.
http://www.ntsb.gov/ntsb/brief.asp?e...24X01867&key=1
If that link is confusing, or doesn't work right, just go to the NTSB site and look up the following:
NTSB Identification: IAD05FA012
14 CFR Part 91: General Aviation
Accident occurred Friday, November 12, 2004 in Paint Lick, KY
Aircraft: Cessna P210, registration: N6539P
Injuries: 1 Fatal.
File this one in the "I'm glad I've got TWO" file.
