Unread 10-03-21, 10:54 PM
kbecker kbecker is offline
where did you have the box overhauled?
Unread 10-04-21, 12:05 PM
Originally Posted by mikes View Post
We have used the CESI ditigal senders on our 421B and C337G w/excellent results
When you had the probes installed, we’re you able to work through the access plates or did you have to remove the upper wing panels on the 337?
Unread 10-04-21, 12:12 PM
GearUp GearUp is offline
Our A&P had to open up the wings (after supporting them) to replace two senders in each main tank, and remove the Flint tip tanks to replace the sender in those.
Unread 10-06-21, 03:43 PM
Tech Aire was the place that I had the unit overhauled
File Type: jpeg 718213B1-EA91-4480-AAC3-AFE8D182AC81.jpeg (277.2 KB, 1378 views)
