Unread 04-13-13, 01:01 AM
SAIB CE-13-27 relates to "Flight Controls – Frayed Flap Extend Cables". Its main purpose is "to remind owners and operators of any airplane with cable-driven flight controls of the importance of adhering to existing inspection procedures" (emphasis added by me). While it "focuses" on 400 Series Cessnas, it "applies to the entire flight control system on any airplane model with cable driven flight controls". And its report that a pilot was unable to retract a flap after the uncommanded retraction of the other flap due to a broken cable is worth mentioning.
Unread 04-25-13, 01:03 AM
Also interesting to note that the pilot was able to control the aircraft with an asymmetric flap condition...it is probably required from an engineering perspective to be designed that way.
Unread 04-25-13, 06:49 AM
JimC's Avatar
JimC JimC is offline
Nope, see above. It doesn't have to be designed that way, but on most GA aircraft it will naturally be that way as part of the average design that makes the ailerons typically not less than 1/2 the flap span. I imagine as you get into more complex systems like the DHC-7 (very large flaps, small ailerons) or the MU-2 (no ailerons at all) that you may get into uncontrollable conditions with an asymmetric flap deployment.
