Unread 04-08-12, 10:29 AM
Fuselage
I have a fuselage that has been stripped of most parts, but structurally it is sound on the bottom end (the pilot side wing area has damage and the very front has damage where the nose gear collapsed).
If you promise not to part her out, you can have the hull. You should be able to drill out the rivets, take the metal you need and swap it out. I have the hull located in halifax north carolina. KIXA airport.
Can you post pictures of your aircraft so I can see the damage and assess if the hull I have will work for you? I will also take pictures of the hull that i have. It is a 337G.
Look forward to hearing from you.
Mike
Unread 04-09-12, 05:50 PM
kdiel11 kdiel11 is offline
kdiel11 is on a distinguished road
Thanks so much for the offer. I'll try and get some pics of the damage uploaded sometime this week. Again, I really do appreciate your offer and hope we can use some parts from yours to put mine back in the air. KD
