  #23
Unread 03-02-06, 12:28 AM
birddog birddog is offline
birddog is an unknown quantity at this point
Earnie, the simulated inopeative procedure for some reason is different than what you stated in the Riley Superskyrocket AFM.
It calls for the following:
1) Propeller control - Full High RPM
2) Throttle - Adjust for zero thrust ( per the table on alt and temp)
I felt this simulation induced considerable more drag than a feathered prop and I was wondering if this was technically correct. If so I could look forward to more than the 350 to 400 FPM we experienced. I,m not sure I can take an aircraft 50' feet in the air and abort a take-off and accuratly judge the stopping distance or how much overrun I may have.
However, you give me 50' feet and 400FPM climb and I'm out of there.
Lovely Wendie
