Unread 08-15-05, 04:40 PM
Mark McConaughy Mark McConaughy is offline
Mark McConaughy is an unknown quantity at this point
Known Icing
Having De-ice boots for the unexpected is great and if I were looking for an airplane it would certanly be a plus. However, I,m not sure if the P210 is certifified for known ice but to the best of my knowledge the P337 (or any other 337 for that matter) is not certified for flight into known icing conditions. I've attached a copy of the reg.
Section 91.527: Operating in icing conditions.
(a) No pilot may take off an airplane that has—
(1) Frost, snow, or ice adhering to any propeller, windshield, or powerplant installation or to an airspeed, altimeter, rate of climb, or flight attitude instrument system;
(2) Snow or ice adhering to the wings or stabilizing or control surfaces; or
(3) Any frost adhering to the wings or stabilizing or control surfaces, unless that frost has been polished to make it smooth.
(b) Except for an airplane that has ice protection provisions that meet the requirements in section 34 of Special Federal Aviation Regulation No. 23, or those for transport category airplane type certification, no pilot may fly—
(1) Under IFR into known or forecast moderate icing conditions; or
(2) Under VFR into known light or moderate icing conditions unless the aircraft has functioning de-icing or anti-icing equipment protecting each propeller, windshield, wing, stabilizing or control surface, and each airspeed, altimeter, rate of climb, or flight attitude instrument system.
(c) Except for an airplane that has ice protection provisions that meet the requirements in section 34 of Special Federal Aviation Regulation No. 23, or those for transport category airplane type certification, no pilot may fly an airplane into known or forecast severe icing conditions.
(d) If current weather reports and briefing information relied upon by the pilot in command indicate that the forecast icing conditions that would otherwise prohibit the flight will not be encountered during the flight because of changed weather conditions since the forecast, the restrictions in paragraphs (b) and (c) of this section based on forecast conditions do not apply.
Here is the excerpt from SFAR 23 (not to be confused with Part 23).
34. Ice Protection.
If certification with ice protection provisions is desired, compliance with the following requirements must be shown:
(a) The recommended procedures for the use of the ice protection equipment must be set forth in the Airplane Flight Manual.
(b) An analysis must be performed to establish, on the basis of the airplane's operational needs, the adequacy of the ice protection system for the various components of the airplane. In addition, tests of the ice protection system must be conducted to demonstrate that the airplane is capable of operating safely in continuous maximum and intermittent maximum icing conditions as described in FAR 25, Appendix C.
(c) Compliance with all or portions of this section tray be accomplished by reference, where applicable because of similarity of the designs, to analysis and tests performed by the applicant for a type certificated model.
Mark M. McConaughy
Oklahoma City, OK
405-745-7861
