Unread 08-07-05, 08:26 AM
It has always been my policy that if I need the tanks full, you have to return to each outboard and check that the fuel is up to the top. This depends on how fast the fuel is dispensed. With high flow nozzles it is a must. I have found that most DIY nozzles have low enough flows that this is usally not a problem. I is important to tell the fuel attendant to check the outboards after he has fueled both sides.
