Unread 04-27-05, 01:31 AM
337G 337G is offline
337G is an unknown quantity at this point
rough engine
Cold is not an issue up here any more Skyking so frosted plugs would not be an issue however perhaps a bad lead or two may be worth investigating. I thought fouled plugs too but after trying to work that out it does not seem to make a difference.
I can't pull the power back below 1200 RPM or it will quit. I run it at 1300 and it is very rough and wants to stall. At the point when I feel that it will stall I give it a shot of the "low" fuel boost pump and it recovers but still runs rough. This may continue for 1 or 2 more times and then it smoothes out enough to run at around 1200 RPM...roughly but it does not stall out on me. After I have been flying and then land it seems to "work" better and the engine allows me to bring it below 1000RPM however it still has a roughness about it.
FYI...the rear engine runs fine.
In any case I have the engineer on it and he knows the 337 very well.
Thanks in advance for every ones input!
Craig B.
