Old 02-21-05, 04:28 PM
Dale Campbell's Avatar
Gear Horn
Another place to look for your horn problem, is the sqwat switch on nose gear. I had a bind in nose gear yoke after my mechanic installed a new seal. The nose wheel did not extend all the way down, after take off, therefore the qwat switch did not transfer and the horn started blowing when I tried to put up gear. Vibration in the front end finally made the nose gear extend all the way and I could put up gear without that horn blasting. If you had wire problem to the sqwat switch it would do the same thing. Dale
